--- title: "Managing Veeam Connections" description: "After you configure initial integration with Veeam Backup & Replication and Veeam ONE servers using the guided setup, you can add more connections or edit existing ones later if required." canonical: "https://helpcenter.veeam.com/docs/security_plugins_servicenow/guide/sn_manage_connections.html" breadcrumb: "User Guide > Managing Veeam Connections" dateModified: "2026-10-08" --- # Managing Veeam Connections After you configure initial integration with Veeam Backup & Replication and Veeam ONE servers using the guided setup, you can add more connections or edit existing ones later if required. ## Managing Veeam Backup & Replication Connections All Veeam Backup & Replication connections are displayed in the **Veeam** > **Configuration** > **VBR Connections** section. [![](images/vbr_connections.png)](images/vbr_connections.png){.toggle scale=80} To add a new connection with the Veeam Backup & Replication server, perform the following steps: 1. Click **New**. 2. In the **Name** field, specify a connection name. For example, *vbrsrv01*. 3. In the **Host** field, specify the FQDN of the Veeam Backup & Replication server. For example, *vbrsrv01.tech.local*. 4. In the **Credentials** field, select credentials you added earlier to connect to the Veeam Backup & Replication server. 5. In the **Port** field, specify the port number you use to connect to Veeam Backup & Replication REST API. The default value is *9419* or *443* (for Veeam Backup & Replication version 13.1 and later). 6. In the **MID Server** field, select the MID Server you configured earlier. 7. To allow a specific user group to use this connection, unlock the **User Groups** field and select a user group from the list. 8. In the **Days To Collect Backup Sessions Data** field, specify the number of days to retrieve initial data about backup sessions. 9. In the **Days To Collect Task Sessions Data** field, specify the number of days to retrieve initial data about task sessions. 10. In the **Days Without Security Checks** field, specify the number of days without scan results to run Security & Compliance Analyzer automatically. 11. Click **Submit**. [![](images/add_vbr_connection.png)](images/add_vbr_connection.png){.toggle scale=80} To edit a connection, click the name of the connection, update required settings and click **Update**. [![](images/edit_vbr_connection.png)](images/edit_vbr_connection.png){.toggle scale=80} To delete a connection from Veeam App for ServiceNow, perform the following steps: 1. Select one or more connections from the list. 2. From the **Actions on selected rows** drop-down list, select **Delete** and confirm the operation. ::: note If you delete a Veeam Backup & Replication server connection, all data collected from this server will be also deleted from the app. ::: [![](images/delete_vbr_connection.png)](images/delete_vbr_connection.png){.toggle scale=80} ## Managing Veeam ONE Connections All Veeam ONE connections are displayed in the **Veeam** > **Configuration** > **Veeam ONE Connections** section. [![](images/vone_connections.png)](images/vone_connections.png){.toggle scale=80} To add a new connection with the Veeam ONE server, perform the following steps: 1. Click **New**. 2. In the **Name** field, specify a connection name. For example, *vonesrv01*. 3. In the **Host** field, specify the FQDN of the Veeam ONE server. For example, *vonesrv01.tech.local*. 4. In the **Credentials** field, select credentials you added earlier to connect to the Veeam ONE server. 5. In the **Port** field, specify the port number you use to connect to Veeam Backup & Replication REST API. The default value is *2471*. 6. In the **MID Server** field, select the MID Server you configured earlier. 7. Click **Submit**. [![](images/add_vone_connection.png)](images/add_vone_connection.png){.toggle scale=80} To edit a connection, click the name of the connection, update required settings and click **Update**. [![](images/edit_vone_connection.png)](images/edit_vone_connection.png){.toggle scale=80} To delete a connection from Veeam App for ServiceNow, perform the following steps: 1. Select one or more connections from the list. 2. From the **Actions on selected rows** drop-down list, select **Delete** and confirm the operation. ::: note If you delete a Veeam ONE server connection, all data collected from this server will be also deleted from the app. ::: [![](images/delete_vone_connection.png)](images/delete_vone_connection.png){.toggle scale=80}
