--- title: "Veeam Monitoring" description: "The Veeam Monitoring dashboard displays aggregated information about jobs related to your Veeam Backup & Replication servers. Specific widgets also display event statistics." canonical: "https://helpcenter.veeam.com/docs/security_plugins_servicenow/guide/sn_monitoring_dashboard.html" breadcrumb: "User Guide > Working with Dashboards > Veeam Monitoring" dateModified: "2026-10-08" --- # Veeam Monitoring The Veeam Monitoring dashboard displays aggregated information about jobs related to your Veeam Backup & Replication servers. Specific widgets also display event statistics. ::: note Consider the following: - Only App Administrators have access to the Veeam Monitoring dashboard. - Data is shown for the last 30 days. If there is no data from a specific Veeam Backup & Replication server, it will not be displayed on the dashboard. ::: [![](images/veeam_monitoring_dashboard.png)](images/veeam_monitoring_dashboard.png){.toggle scale=80} The dashboard includes the following widgets:
Widget
Description
Alarms by Day
A colored stacked bar chart displaying the breakdown of Veeam ONE triggered alarms by day. By default, the widget displays data for the last 30 days.
Alarms by Status
A pie chart displaying the breakdown of Veeam ONE triggered alarms by status. By default, the widget displays data for the last 30 days.
Malware Events by Day
A colored graph displaying the breakdown of malware events by day. By default, the widget displays data for the last 7 days.
Four-Eyes Authorization Events by Day
A colored graph displaying the breakdown of four-eyes authorization events by day. By default, the widget displays data for the last 7 days.
Four-Eyes Authorization Events by State
A pie chart displaying the breakdown of four-eyes authorization events by state. By default, the widget displays data for the last 30 days.
Malware Events by Status
A pie chart displaying the breakdown of malware events by severity level. By default, the widget displays data for the last 30 days.
Security & Compliance Analyzer Results by Status
A pie chart displaying the breakdown of Security & Compliance Analyzer scan results by status. By default, the widget displays data for the last 30 days.
All Backup Job Sessions per User
A colored stacked bar chart displaying the breakdown of backup job sessions by user. By default, the widget displays data for the last 30 days.
All Backup Job Sessions by Day
A colored stacked bar chart displaying the breakdown of backup job sessions by day. By default, the widget displays data for the last 30 days.
All Backup Job Sessions by Result
A pie chart displaying the breakdown of backup job sessions by state. By default, the widget displays data for the last 30 days.
All Unstructured Job Sessions per User
A colored stacked bar chart displaying the breakdown of file backup job sessions per user. By default, the widget displays data for the last 30 days.
All Unstructured Job Sessions by Day
A colored stacked bar chart displaying the breakdown of file backup job sessions by day. By default, the widget displays data for the last 30 days.
All Unstructured Job Sessions by Result
A pie chart displaying the breakdown of file backup job sessions by state. By default, the widget displays data for the last 30 days.
All Application Events with High Risk Level
The total amount of application events with the High risk level. By default, the widget displays data for the last 24 hours.
All Application Events by Risk Level
A pie chart displaying the breakdown of application events by risk level. By default, the widget displays data for the last 30 days.
All Application Events by Type
A colored stacked bar chart displaying the breakdown of application events by type. By default, the widget displays data for the last 30 days.
To view detailed information on specific data, click a value on a widget. A table with filtered results will be opened.
