--- title: "Veeam Data Platform Monitoring" description: "The Veeam Data Platform Monitoring dashboard displays aggregated information about jobs run on your Veeam Backup & Replication servers. By default, data is shown from all data source hosts." canonical: "https://helpcenter.veeam.com/docs/security_plugins_xsiam/guide/xsiam_dashboards_monitoring.html" breadcrumb: "User Guide > Dashboards > Veeam Data Platform Monitoring" dateModified: "2026-08-21" --- # Veeam Data Platform Monitoring The Veeam Data Platform Monitoring dashboard displays aggregated information about jobs run on your Veeam Backup & Replication servers. By default, data is shown from all data source hosts. To filter data, you can select specific time period or data source host. ::: note If there are no events from a specific data source, it will not be displayed on the dashboard. ::: [](images/dashboard_monitoring_general.png){.toggle scale=80} The dashboard includes the following widgets:
Widget |
Description |
Failed Jobs |
The total amount of jobs finished with the Failed status. By default, the widget displays data for the last 24 hours. |
Transferred Data |
The total amount of data transferred during backup jobs and file backup jobs. By default, the widget displays data for the last 24 hours. |
Backup and Copy Jobs: Daily Report |
A colored graph displaying daily statistics on finished backup and backup copy jobs. By default, the widget displays data for the last 7 days. |
SureBackup Jobs: Daily Report |
A colored graph displaying daily statistics on finished SureBackup jobs. By default, the widget displays data for the last 7 days. |
Latest Configuration Backups |
A table displaying information about the latest configuration backup job run on each Veeam Backup & Replication server. By default, the widget displays data for the last 30 days. |
Finished Jobs by State |
A set of pie charts displaying the breakdown of finished jobs by state:
By default, widgets display data for the last 30 days. |
Latest Finished Jobs |
A table displaying detailed information about the latest finished jobs on each Veeam Backup & Replication server. By default, the widget displays data for the last 30 days. |
Finished Jobs by Type |
A colored stacked bar chart displaying daily statistics on finished jobs by type. By default, the widget displays data for the last 7 days. |
