--- title: "Working with Veeam Incident Dashboard" description: "The Veeam Incident Dashboard displays aggregated information about incidents related to your Veeam Backup & Replication and Veeam ONE integration instances. Specific widgets also display incidents related to integration health state." canonical: "https://helpcenter.veeam.com/docs/security_plugins_xsoar/guide/xsoar_dashboards_incidents.html" breadcrumb: "User Guide > Working with Veeam Incident Dashboard" dateModified: "2026-09-07" --- # Working with Veeam Incident Dashboard The Veeam Incident Dashboard displays aggregated information about incidents related to your Veeam Backup & Replication and Veeam ONE integration instances. Specific widgets also display incidents related to integration health state. [![](images/xsoar_incident_dashboard.png)](images/xsoar_incident_dashboard.png){.toggle scale=80} ## Adding Dashboard To start using the dashboard, you need to add it to your workspace. To do this, perform the following steps: 1. In the main menu, click **Dashboards & Reports**. 2. On the **Dashboards** tab, click **More dashboards** and select the dashboard from the list. [![](images/xsoar_incident_dashboard_add.png)](images/xsoar_incident_dashboard_add.png){.toggle scale=80} ## Dashboard Details The dashboard includes the following widgets:
Widget
Description
All Incidents
A colored graph displaying daily statistics on the following incidents:
  • Veeam Backup & Replication active and closed incidents
  • Veeam ONE active and closed incidents
  • Incident fetch errors
Veeam Backup & Replication Active Incidents
A colored graph displaying daily statistics on Veeam Backup & Replication active incidents. If the incident is closed, it disappears from the graph.
Veeam ONE Active Incidents
A colored graph displaying daily statistics on Veeam ONE active incidents. If the incident is closed, it disappears from the graph.
Incidents by Type
A pie chart displaying the breakdown of incidents by type. Note that data is shown for the last 2 days.
Incidents by Source
A pie chart displaying the breakdown of incidents by source. Note that data is shown for the last 2 days.
Command Execution Errors per Instance
A pie chart displaying the breakdown of command execution errors by integration instance.
A pie chart displaying the breakdown of command execution errors by name.
Veeam REST API POST Requests
A colored graph displaying daily statistics on POST requests sent to Veeam REST APIs.
Latest Veeam Backup & Replication Incidents
A table displaying information about the latest incidents on each Veeam Backup & Replication integration instance.
Latest Veeam ONE Incidents
A table displaying information about the latest incidents on each Veeam ONE integration instance.
By default, data is shown for the last 7 days. To filter data, you can specify another time period. To view detailed information on specific data, do the following: - For pie charts or colored graphs, click the category. - For tables, click the incident ID in the **ID** column. A new window with the search query will be opened. [![](images/xsoar_incident_dashboard_view_query.png)](images/xsoar_incident_dashboard_view_query.png){.toggle scale=80}
