--- title: "Deleting Instances" description: "If you do not plan to use an integration instance anymore, you can delete it. To do this, perform the following steps: In the main menu, click Settings. On the Integrations > Instances tab, search the integration and open instance settings." canonical: "https://helpcenter.veeam.com/docs/security_plugins_xsoar/guide/xsoar_instances_delete.html" breadcrumb: "User Guide > Working with Instances > Deleting Instances" dateModified: "2026-09-07" --- # Deleting Instances If you do not plan to use an integration instance anymore, you can delete it. To do this, perform the following steps: 1. In the main menu, click **Settings**. 2. On the **Integrations** > **Instances** tab, search the integration and open instance settings. 3. In the **Instance Settings** window, select the **Delete** check box and click **Delete**. ::: note Deleting an instance does not affect incident data. If you add the same instance again later, incidents fetched from this instance will be displayed on the Veeam Incident Dashboard and in the reports. :::
