This is an archive version of the document. To get the most up-to-date information, see the current version.Running and Scheduling Failover Plans
After you create and configure a failover plan, run a successful readiness check and a DataLab test, the plan can be considered ready for failover. You may invoke various actions for the plan, depending on the current plan state.
Failover plans may acquire the following stable states:
Plan State | Icon | Description |
NOT VERIFIED |
| Plan has never been tested and/or has never passed a readiness check. |
| Plan has failed to be tested and/or has failed to pass a readiness check. | |
VERIFIED |
| Plan has been tested successfully and/or has passed a readiness check. |
HALTED |
| Plan has stopped due to either an error or user intervention. |
FAILOVER |
| Failover process completed successfully. |
| Failover process completed with warnings. | |
| Failover process completed with errors. | |
UNDO FAILOVER |
| Undo Failover process completed successfully. |
| Undo Failover process completed with warnings. | |
| Undo Failover process completed with errors. | |
PERMANENT FAILOVER |
| Permanent Failover process completed successfully. |
| Permanent Failover process completed with warnings. | |
| Permanent Failover process completed with errors. | |
FAILBACK |
| Failback process completed successfully. |
| Failback process completed with warnings. | |
| Failback process completed with errors. | |
UNDO FAILBACK |
| Undo Failback process completed successfully. |
| Undo Failback process completed with warnings. | |
| Undo Failback process completed with errors. | |
COMMIT FAILBACK |
| Commit Failback process completed successfully. |
| Commit Failback process completed with warnings. | |
| Commit Failback process completed with errors. | |
TESTING HALTED |
| Plan testing has stopped due to either an error or user intervention. |
Failover plans may acquire the following active states:
EDITING |
| Plan is currently being edited. |
FAILOVER |
| Plan is currently being executed. |
| Plan is currently being executed, a number of warnings encountered. | |
| Plan is currently being executed, a number of errors encountered. | |
TEST PENDING |
| Plan testing has been started, but the DataLab required to test the plan has not been powered on yet. |
TESTING |
| Plan testing is in progress. |
| Plan testing is in progress, a number of warnings encountered. | |
| Plan testing is in progress, a number of errors encountered. | |
TEST HALTING |
| Plan testing is currently being halted. |
CHECKING |
| Plan readiness check is in progress. |
| Plan readiness check is in progress, a number of warnings encountered. | |
| Plan readiness check is in progress, a number of errors encountered. | |
CHECKING HALTING |
| Plan readiness check is currently being halted. |
HALTING |
| Plan is currently being halted. |
POWERING OFF |
| Plan testing is currently being powered off. |
If you perform any infrastructure configuration changes (add, delete or rename VMs) or changes to Veeam ONE Monitor groups, VAO will not automatically apply these changes to plans that are currently executing or testing — such plans are ‘locked’ and may not be edited. The changes will take effect only if the plans enter the VERIFIED or NOT VERIFIED state. |
Failover plans may acquire the following modes:
Plan Mode | Icon | Description |
ENABLED |
| Plan is ready to be verified and executed. Plan editing in this mode is not available. Automatic report updates in this mode are enabled. |
DISABLED |
| Plan is ready to be edited and verified. Scheduled plan execution in this mode is not available. Automatic report updates in this mode are disabled. |
IN USE |
| Plan is either in one of the active states (except the EDITING state) or in one of the stable states (except the VERIFIED and NOT VERIFIED states). Plan editing and disabling in this mode are not available. Automatic report updates in this mode are disabled. |
When a plan is in an active state, you can switch to the Plan Details page, select a VM being recovered in the Virtual Machines column, and click the VM Console link to connect directly to the VM desktop. VAO will connect to the VM through the vCenter Server system. To avoid connection failures, make sure the following requirements are met:
Before You Begin
To run a failover plan, it must be ENABLED. To enable a plan:
- Log in to the VAO UI as a VAO Administrator or Plan Author. For details, see Accessing VAO UI.
- Navigate to Orchestration Plans.
- Select the plan.
- From the Manage menu, select Enable.
In This Section
